Help me out with this if you can.
Before removing my existing distributor I took off the rocker cover on my big block 400 (the right hand one as you look at the car from the front), turned it over clockwise until number one (front right) was opening and then closing on the inlet and a little more until both the pushrods on the inlet and exhaust valves could be spun freely by hand.
Once there I checked on the damper and was happy to see a nice big pressed in factory dot, lined up with 0 on the TDC gauge original to the engine. I marked this with tipex so it was clear. Happy days...
Got the new distributor in, same place (there abouts). Car fired up and didnt really like it. TDC could not be seen at this point with a timing light (I think it was hiding under the strip of metal right at 12 would be on a clock fave) So from what I can see the damper is not moving around.
I moved the distributor until the car was more happy by ear, turning it clockwise which made it worse and then anticlockwise. by a good 15* or so.
The timing light was showing TDC as being no where near the factory gauge showing 0-20 advance (which is around 11 to 12 on a clock face). In fact it was picking up the mark I had made on there at about 1-2 on a clock face, where there is no gauge to show what advance/retard you are running.
I'm confused to say the least. The engine is not original maybe I am doing this wrong (it was going well and to plan until the timing light came out
The timing light is working, I have two, they both show the same. I am working on No1 for sure.
Regardless of the above the car runs like a dream, pulls clean 0-5500 rpm with no bogs or miss fire. I'm guessing I am at about 16* advance at idle with 35ish all in. But I'd like to find out the logic behind the above.
Thanks!
Jon
