brake pedal pressure
Since doing my disc brake conversion I've been disappointed with the pedal pressure.Just had it pointed out to me that the master cylinder has" use dot 3 fluid" stamped in it .Would using later dot 4 fluid damage the piston seals?
do it in a dodge
DOT 3/4 are mineral so will both be OK to use.
Your pedal pressure feel is down to the fact you've gone from drums to discs and your master cylinder now has to move more fluid.
You will have to get a bigger bore m/cyl. You'll need a m/cyl which is for disc/drum setup. 1 1/8" I think.
68 Plymouth Sattelite 383ci
I had the same problem when I fitted front disks. Changed from a 1 1/8" master cylinder to a 15/16" and there was an improvement but still a lot of pressure required and the pedal travel increased. In the end I fitted a servo and went back to 1 1/8" MC and I'm happy with the brakes now.
Thanks for replies guys.new master cylinder and servo fitted with the kit,but the pedal travels too far before I get any pressure.there's no gap between the rod and the piston and no air, or fluid leeks in the system.might try a piston seal renewal kit if I can get one.
do it in a dodge
