leaky Crankcase Ventilator valve
Garp
Post by Garp »
Was having a "gander" under the hood this morning after having taken a spin and shock-bloody-horror, I see oil in neat little puddles on top of the block. I also notice that my once clean air filter is looking a tad grey and that there is a small oily patch on the inside of the hood.
After checking the underneath of the car and the current oil level after cooling all I can seem to put this down to (and it would make sense) is a father ill-fitting conection to the crankcase ventilator valve - I've seen so many different versions but mine is a simple loose press-on rubber cap style with a hose connection above it ... I guess under load this must've popped off. It's also really easy to pull off.
Can someone recommend a good fix, or a suitable alternative for the 340ci V8 ? I know it's not going to kill the motor but I'd like to nip this in the bud before my entire engine bay has a fine dusting of oil.
Thanks in advance
Garp
Garp
Re: leaky Crankcase Ventilator valve
Post by Garp »
Garp wrote:Was having a "gander" under the hood this morning after having taken a spin and shock-bloody-horror, I see oil in neat little puddles on top of the block. I also notice that my once clean air filter is looking a tad grey and that there is a small oily patch on the inside of the hood.
Thanks in advance
Garp
Upon closer inspection, the rubber plug that fits into the rocker-cover head has been trimmed down with a knife and made to fit (possibly was too big) but whoever did it overdid it and it is now too loose and the glue/cement holding it in place has perished and no longer works - heat proof engine glue ? Anyone ?
I would replace the grommet or you will be constantly chasing it. Easy fix :thumbright: :thumbright:
