Hello, I sprayed my charger a good few years ago and all went well. I have started doing a bit of spraying again (not on the charger or car) Problem is I keep getting fish eyes.
Im wondering if its to do with the panel wipe.
Im using U-pol slow degreaser/panel wipe, is this the best thing to use?
I wipe it on, then wipe off with clean cloth and leave it for about 1/2 hour before tacking and then spraying.
Any tips or advise?
Paint spraying advise
1969 Dodge Charger
1972 Chrysler Hardtop
I never use anything from UPol anymore. Also make sure you have no contaminants in your compressor. Any silicone in the painting area will cause problems as well. You can get an additive to stop these imperfections, but once you start using it, you will always have to use it.
