Woah - had quote for repairs to Charger
SammyH770
Post by SammyH770 »
I have had a quote for the following repairs:
Steering box rebuild
Recon propshaft
Exhaust repairs
(not including changing carb and manifold)
£2,300
:shock:
Custom Car want to do a feature on the car so he would have been getting a bit of free advertising.
Keep your kittens and handbags and gimme a V8 any day ☺
shovelheadrob
Post by shovelheadrob »
I think you need to find somewhere else, I'll ask someone I know & trust who is in Peterborough, he doesn't advertise & he's relatively cheap. If you want to pm me your contact details I'll let you know.
again this seems excessive.
the fella who had your car before you had that steering box rebuilt about 4 years ago and then never drove the car
so either
1) he didn't get it done (if he didn't he talked a good story over weeks of posting)
2) he was conned (possible)
3) the rebuilder didn't set the worm shaft bearing pre load followed by the sector to ball nut mesh
in which case that needs to be done before you consider a rebuild.
I have a prop shaft that can help
I can get it to Watford any work day you happen to be passing in your truck :)
give me notice and i'll dig it out, check it out, swap the worst UJ with a better one that I have in a box, taken from my car not because it was an issue but because the rear one fell to bits, cup fell off and the rollers came out) when I took out the prop last time, the new ones come in a kit of 2 and I replaced both.
that means I have 1 good second hand one in a box somewhere.
pentastar parts and restorations do a 2 UJ kit for your car for $35
if you want a rebuild kit for your steering box
or want a rebuilt steering box
www.Pentastarparts.com.au
buy a box from them
buy a broken one on aussie ebay $100-$150
send it to them as your exchange core
recon steering box is $450
750 if you don't supply a rebuilder
however companies like JayGee in the UK can rebuild a Saginaw power steering box.
yours will probably be a 1 1/16 sector shaft box 27mm
they also came with a 1 1/8 diameter sector shaft 30mm
Adjust what you have first though other wise just wasting cash
ANTON
Post by ANTON »
Proshaft services in Feltham charge about £120 to fit new ujs and re-balance a prop.
A full new stainless steel exhaust build is around £740 including silencers.
As Dave says get the steering box checked out first before you rebuild. Is this manual or power
Carb and manifold swap if you supply the gaskets, manifold and carb will be around £120 - £150
What is wrong with the exhaust.
www.apdautomotive.co.uk
APD Automotive
22 Willow Lane
MITCHAM
CR4 4NA
0208 6400729
68Runner
Post by 68Runner »
Christ that's expensive.
When I was building my Pro Street truck everything was made to order.
Brand new Propshaft(Hauser racing) under £200
Manifold back exhaust in Stainless £400 (There is a guy I know in Newark)
BASICALLY HE IS CONNING YOU OUT OF HARD EARNED CASH
68 Plymouth Sattelite 383ci
:shock:
I'd be asking for a meal first before getting screwed like that!
I'd go with Anton and his numbers......Save yourself nearly a grand!
Like some builders,I reckon he's priced it that way because he doesn't really want to do it. Of course if you accept the quote he laughs all the way to the bank. Forget that garage.
ANTON wrote:What is wrong with the exhaust.
from the pictures it look like rust holes at the lowest point in the system after the manifold ends in the header pipe.
it looks like a chop it out and weld in a new bit job to get you going with the option of a full new, manifold to silencer pipes later on.
I belive this will have cast single outlet manifolds with the ball and ring style clamps holding on a flared header pipe at each side
i.e 1 bent pipe to the drivers side (RHD) with a flared end and sliding flange with two bolts at one end. welded or slip jointed to the main system at the other
PS nothing wrong with your steering box
No drips no grease no oil coming out :)
latil wrote:Like some builders,I reckon he's priced it that way because he doesn't really want to do it. Of course if you accept the quote he laughs all the way to the bank. Forget that garage.
Or they are taking the pee by 'Its a woman wanting the work done.....Add £££ as they wont know'.
As I said in the other post. Expensive (Dougs) headers £600 delivered. Summit Exhaust system with mufflers is circa £250. Say £150 to fit.
That's a brand new expensive system for £1k.
The price for me is just a p take. A new manifold back system shouldn't cost more than £300-£400 all in fitted.
So £1900 for a propshaft and PS rebuild............ :help:
ANTON wrote:Proshaft services in Feltham charge about £120 to fit new ujs and re-balance a prop.
In case you Missed it that sounds like an offer.....
You should contact Dave Billadoo he does this stuff all the time he will be able to give you a much more on the money price to sort it out, N if he wants to fuc6 you in the as3 it wont hurt as he has a little pecker,, ;)
SammyH770
Post by SammyH770 »
Thanks for all your advice. Definitely won't be using that garage. Pete is coming to look at the car in a week or so to give me his opinion :)
Its all so mind-boggling, not sure what to do.
A 600 cfm vac sec holley carb and inlet manifold and gaskets (the whole lot) from Real Steel is £664.49 delivered. Ouch.
I don't think the exhaust will be an issue I can get that done anywhere I guess. I just spoke to Bailey Morris about the propshaft but I would need to take the propshaft out and take it to them, I can't do that, I wouldn't know how to get it out or put it back in.
I think the steering problem is going to be a big issue, if it has already been rebuilt then there's not much else can be done but there is so much play, its probably quite dangerous really. The mechanic said it looked like it had some work done on it so to replace it instead but then he said you can't get a replacement so it would have to be rebuilt.
Hmmm.
:cry:
1) A 600 cfm vac sec holley carb and inlet manifold and gaskets (the whole lot) from Real Steel is £664.49 delivered.
2) I just spoke to Bailey Morris about the propshaft but I would need to take the propshaft out and take it to them, I can't do that, I wouldn't know how to get it out or put it back in.
3) I think the steering problem is going to be a big issue, if it has already been rebuilt then there's not much else can be done but there is so much play,
:cry:
1) get the inlet of Stu and Gareth and get a second hand carb
carb
http://www.ebay.co.uk/itm/Holley-Carbur ... Sw9mFWNQ3S
looks like it lived in the sea
here is one at £60 with 3 days to go that looks nice
http://www.ebay.co.uk/itm/Holley-600CFM ... SwKtlWp8Et
although I'd buy one that some one is willing to say works.... like someone on here
2) I'll check my spare prop-shaft out tonight. you will need it before the weekend if you want uncle Pete to fit it. (I know he is just coming for a look but I'm doing my best to play on his conscience)
3) rebuilt but not adjusted. once adjusted it could be fine.
1st adjustment should be done with box off car by rebuilder as part of the rebuild
THE second is usually done on car
PROBABLY Not done by previous owner because he was not mechanically minded
he probably just fitted it as it was fresh from the rebuilder
1st adjustment
undo hex ring
whack the bloody box top round a bit
do up hex ring
2nd
adjust the sector mesh so the box is stiff in the middle with the wheels off the ground. once engine is running no stiffness will be noticed
Get Pete to do that.
Job done
He loves that kinda thing probably
