which way round for dished washers on shock mount rear
hello
as it says
the shocks at the rear bolt up with dish shaped washers either side of the rubber bushes
should they cup the end of the rubber or should they pin the middle near the bolt in tight letting the rubber bulge towards the edges
neither way looks particularly good
i.e conCAVE in towards the rubber, convex to the nut or concave out towards the metalwork or nut.
(0) or )0(
currently (0) cos that's how it was with the old shocks
(0). The only washers I've come across on a Mopar that go the other way round are on the strut rod bushes in the K frame.
ANTON
Post by ANTON »
(0) as on all I have worked on
www.apdautomotive.co.uk
APD Automotive
22 Willow Lane
MITCHAM
CR4 4NA
0208 6400729
Yes (O) as above. Only K frame strut rods go )O(.
wicked
they are on the right way then
many thanks
Dave999 wrote:wicked
many thanks
It's not like you to be conventional and go with the Flow, Dave ;)
yeah but there is nothing worse than your bushes being gripped the wrong way.
