I'm after some ideas on how long or rather mileage before any real full throttle high rev driving since my light engine refresh please.
I'm running the same cam, lifters, rods and rockers. I replaced the main and big end bearings, timing chain and gear and all piston rings, so I was just wondering if there's a rough guide or train of thought on running an engine after this?
It's mainly the rings that will need to bed in.I'd reckon 500-1000 miles with plenty of running at varied speeds without any high loads. I'd also change the oil/filter at 500 and again at 1000,then back to normal use.
By the time the cam is broken in the rings should be bedded in also so personally it's drive it like you stole it time. Personally I'd change the oil & filter before 500 miles. This is another one of those questions where you'll get 500 different answers...
I'm a firm believer that the old "running in" routine was just a load of nonsense.
Blue wrote:Personally I'd change the oil & filter before 500 miles. This is another one of those questions where you'll get 500 different answers...
I'm pretty much aligned with Blue on this one...
I personally would change the oil not long after the cam has bedded in. I agree during the initial fire up, you want good fuel mix ratio, to ensure no bore wash, etc. This is the time the rings really bed in.
If you follow the 'running in' process, then surely they would 'run out' as quick 😊
Geof Hauser told me to fire it up (roller cam so easier, but it is not an issue on this occasion) wait for the oil pressure to stabilise (i.e. drop) and then give it large.
I did that and then gave the car a gentle (high 10 second) pass and then nailed it thereafter. No issues at all.
I am a firm believer in early oil and filter changes though, however Geof gave their Super Pro-ET car 19 passes on break in oil before a change.....
Same cam so agree it's just bedding the rings. You need load (intermittent yes, but you need load) to do that so in the car on the road, or on a dyno. Also depends on the type of rings & the appropriate hone some bed quickly. But def worth getting them properly seated. Listen to this lot who've been there and done it a lot, then as said Bananarama! mercilessly. Production engines in a car factory don't get 500 miles, they get fired up, run in, then good to go. Once the rings have sealed (or not sealed, hopefully not) you've got what you've got!
Gavin Chisholm - 414ci W2 Stroker SmallBlock Panther Pink '71 Challenger convertible - in bits Car progress can be viewed here
Also depending if it's a new unit with warranty and guarantees so you would normally stick to the engine builders strict code of advice normally 500 miles.
I know I did with my new engine after all you break it you paye for it so what's a few extra miles breaking it in carefully.
It's your wallet.
I built my engine and broke the cam in on a Saturday and the next Friday drove tot he Nats and laded down 20 passes and that engine is still going strong.
After came break in change oil and filter and have some fun.
www.apdautomotive.co.uk
APD Automotive
22 Willow Lane
MITCHAM
CR4 4NA
0208 6400729
