Duster Update
Duster70
Duster Update
Post by Duster70 »
Hi Guys, been a while.
Garage extension finally completed, laid floor tiles and moved model railway before rescuing the Duster from my mates house.
Have removed dash components to replace original wiring loom.
Speedo was not working and have contacted Adrian Sidwell in Radstock but have, as yet, had no reply. Has anyone had a speedo/gauge checked and who did you use?
Also, would like to get the ammeter modified to a volt meter so that all original instruments work.
One of the dash light components was missing, any one have a spare that I could purchase?
As work progresses I shall start a thread on the Workshop Forum.
As this appears to the final year at Shakey will try to get to more events and, hopefully meet more Mopar owners.
Regards
Arthur
P1000085 - Copy.JPG (232.27 KiB) Viewed 2334 times
great, what sort of a building is that ?? any better pics ??
Duster70
Post by Duster70 »
Hi Mr Watts, just your average block built garage with 50mm thick insulation panels on the walls and under the roof panels.
Duster70 wrote:Hi Mr Watts, just your average block built garage with 50mm thick insulation panels on the walls and under the roof panels.
great i bet that has improved it know end,, did you find a cheap supply ???? i imagine it runs expensive ??
Duster70
Post by Duster70 »
They are not cheap but very effective way of covering large areas.
Having a friendly local builder who took me to the merchants, put them through on his trade card and we loaded them into his lwb Transit to get them back to my place............Priceless!!
Duster70
Post by Duster70 »
A few more photos:
Good old Celotex?
I have just put about £2k's worth in the cottage extension, but works well.
Great car 8-)
Duster70
Post by Duster70 »
Yes Pete, it is Celotex. Bit pricy but very effective. Garage now warmer in winter and cooler in summer.
Just as well, I think I shall be spending quite a bit of time out there!!
terryr
Post by terryr »
nice ,what sort of tiles have you used,was thinking of doing my floor in something rather than paint
Duster70
Post by Duster70 »
Hi Terry,
I have used Dyno Tiles mounted on closed-cell plastic underlay. The underlay contains any dust produced, insulates and stops the 'clack clack' as you walk on them.
Easy to clip together and a little washing up liquid on each connector means you don't have to resort to GBH with a rubber mallet.
Good online site.
could you please take a couple of pics of your floor,, :shock: :D
terryr
Post by terryr »
and I soppose if your floor gets dirty ,you could always run a duster over it ,,lol ,,hmm I looked into the rubber matt ones like that ,but I don't think it would agree with me wheeling cars around on the trolley jack
70_charger
Post by 70_charger »
Shakey have released a press saying full 2017 events Callander will run :thumbright:
70_charger wrote:Shakey have released a press saying full 2017 events Callander will run :thumbright:
So two years of events then........ 8-)
