Manual Steering Box to "K" Frame bolt Torque
I have just been through the manual and unless I missed it there is no specified torque for the 3 bolts that hold the box to the "K" Frame.
I appreciate that they need to be "FT" but I was thinking of torquing them to 60 Foot lbs.
Any views please?
Thanks
DaveBishop
Post by DaveBishop »
Hi Pete
My manual say 80 ft lbs
Cheers Dave
2 x 1969 Dodge Darts
DaveBishop wrote:Hi Pete
Cheers Dave
Brilliant, thanks Dave!! :thumbright: :thumbright: :thumbright: :thumbright:
It still won't be enough 😒
Thanks Dave - I have fabricated and welded in braces in the past, but that still does not stop the bolts coming loose!!!
drill and wire the heads (coat hanger works :) )
or put the bend over tabs usually reserved for lower ball joint to stub mounting on
or if the bolts don't end in a blind hole nylock the stub that sticks through the welded on nut or threaded section of the K
as you can tell I have no idea how a US box mounts up
mine is tied to the chassis rail with bog roll and envelope sticky.
last resort
dip the bolts in salt water :) they'll soon rust in place
