EXHAUST MANIFOLD STUD
Muckyay
Post by Muckyay »
Having gone to replace what i thought was a leaking manifold gasket i have found that the back manifold stud on the drivers side is in a bad way, its buggered and the thread in the block is too. Im thinking i need to re-tap the hole in the block and use a slightly larger stud? Obviously this stud goes into a water jacket so needs to be done properly. Any ideas?? :shock: :help:
challenger
Post by challenger »
its a fairly simple job assuming you have room to get a 90 deg drill down there aswell as a tap, drain cooling system first drill out to larger size but remember to make sure exhaust manifold is large enough to accomodate the larger stud, remember to seal the thread with rtv. obv if there aint room for the drill its head off time
keep it mopar !
Muckyay
Post by Muckyay »
Will be a squeeze to get a drill down there but will see how we go! Theres not much room there on the old Valiant!
I had the same problem, and used a 90 degree drill,I had no luck,ended up building a new engine,
but if you pull the head, it will be much easier, I know not a good option, but if you booger it up on the car ,it will have to be pulled anyway,I KNOW very frustrating ,good luck ;)
An alternative suggestion. I have thick TTI gaskets on my car and have used similar in the past. You might find that just 5 bolts will seal up with a good gasket, not the tinny thin crap that comes as standard. As you need gaskets anyway, why not get some and try that? Could save a real pain of a job for not much outlay.
http://www.ttiexhaust.com/Category-Misc ... langes.htm
Hughes engines can supply them.
Dart Vader
Post by Dart Vader »
took my heads off, got them done locally by an engineer. re tapped and new stud, no drips now, great peace of mind and cheap to do. think it was 30 quid to have both done
1970 Dodge Dart
1995 Mustang GT
1980 MGBGT
if you can get the stud out
heli-coil or uni-thread
http://www.uni-thread.com/
this obviously involves drilling it out to a bigger size
but avoids the larger stud.
if done well is just as strong as it was originally
access might be an issue
but I guess if you are willing to cut up the installation tool it too can be fitted into the chuck on a 90 degree drill attachment and be turned by hand
