After realising that the source of my rocker cover leak was due to the case being over-pressurized ( PCV on one rocker, non-breathable filler cap on the other) I replaced the filler cap with a little dome breather and no more leak.
Over time and because I have those stock MOPAR ali' rocker covers that have no baffles, the sponge in the breather has taken up oil and is now, albeit slowly, leaking out during a drive and covering all my pretty coloured plug leads in oil droplets.....
Can I find a "baffled breather" with a lock-in bayonet fit ?
Is there a "home-fix" that anyone has done without the need to remove the rocket/replace gasket ?
thanks in advance
garp
