Front spring Compressor
Bryan
Post by Bryan »
What flavour do you guys recommend/use?
I currently have these but have not used them yet.
http://www.drapertools.com/product/6861 ... ressor-Set
With 4 points of contact those look pretty reasonable. You have to be a bit careful with most types to be honest, they are usually doing thier utmost to slip off and maim you...
DaveMadders
Re: Front spring Compressor
Post by DaveMadders »
Bryan wrote:What flavour do you guys recommend/use?
Depends on what car.
If its your Fairlane then you should use a compressor that drops down the centre of the spring once the shock is removed
Dave Madders 0161 428 4281
Bryan
Post by Bryan »
Thanks Dave,
yes its on the Fairlane. I will see if i can find one that goes down into the spring.
