This is a rare event! It was running great then just cut out.
It seems to be my Mallory IV HyFire ignition controller that's packed in as far as I can tell but I'll do more checks before I take the plunge and replace it.
I recently fitted a Mallory retard unit, anyone heard of these causing a problem or causing damage to an ignition?
Anyone have a good tested MSD or similar up for grabs?
I'm looking at the MSD Streetfire as about the only option I can afford- £150 from Amazon. MSD6AL are nearly double that!
Belve broke down!
Belve broke down!
challenger
go to a website called telematica there based in greece and stock all msd,accel etc a lot cheaper than over here and no postage
https://www.telematica.uk.com/supplier/MSD-Ignition
keep it mopar !
- Powermyster
- latil
I think it will only generate the small output when the ignition is on and dissy rotating,I presume there is a feed to the coil to energise it. The test for ohms is to check the continuity of the coil.
