fuel gauge wiring
GJUK
fuel gauge wiring
Post by GJUK »
Hi,
Though I have had most other electrical components out of the dart at some point in time, I've not had the dash out yet.
I can't see (thanks to a roll cage bar under the dash :D) where the plug is on the rear on the dash cluster. I know there is a sender in the tank, which goes via a blue cable all the way to this gauge; it does not work though. In the past it has, kind of ish and been spot on level wise (give or take a full tank of petrol).
Any suggestions for getting it to work again?
I've tried grounding the sender cable, it does nothing now. In the past it used to move a little bit, to about 1/4 tank then give up.
I don't really want to do anything electrical on the car ever again but I could do with knowing how much fuel is in it.
There used to be a clip on strap to earth the tank to the fuel pipe. Often it pays to put in an additional earthing strap as these old ones corrode and make a bad contact.
Do you have the original tank or a fuel cell? Fuel Cells need to be earthed too for a variety of reasons.
GJUK
Post by GJUK »
Oh.
Oh....
That makes sense then, perhaps.
I had a the tank replaced with a new replica type, I can not recall any 'earth device of any sorts between the fuel tank and the shell.
That could explain quite a bit. Thanks Pete.
Will look like this; http://www.classicindustries.com/produc ... mf290.html
It bridges the rubber fuel line right by the tank,connecting the tank outlet to the metal fuel line.
GJUK
Post by GJUK »
Never seen one of these on the underside of the car :D
Thanks guys. :thumbright:
