Cam bearings which would be your preferred manufacturer?
dubvalman
Post by dubvalman »
This question goes out to all the engine builders out there;
LA 318: The engine is NOT a performance/big horse power engine - Daily driver (Miss Daisy style) - and no it will not be considered for tweaking and up-rating. That's another project.
When selecting replacement cam bearings which would be your preferred manufacturer?
Criteria;
  • Durability
    Quality of material
    Fit
    Tolerences
The providers to choose from are as follows (try and stick to those listed please)
Clevite
Dura-Bond
King Engine Bearings
the price point on the above is close from the particular supplier so in this instance it is not a factor.
I would use any of them, there is next to no load / wear on cam bearings.
Dart Vader
Post by Dart Vader »
I've had Cleevite in both chevy and mopars
Never had a problem.
Suspect they all come out of the same factory in China or Mexico anyway.
Rockauto are cheap for stuff like this and shipping reasonable
Discount code in traders section
1970 Dodge Dart
1995 Mustang GT
1980 MGBGT
shovelheadrob
Post by shovelheadrob »
I would be more concerned about who is fitting them & how. As Pete says they are not a high load area. I always changed them as I had blocks hot tanked & you can clean out everything better with them out but installation is critical & I've seen some installed badly over the years.
Yep, agree with all of the above.
