318 poly in my neighbour's 1966 Bristol 409.
Book timing says 7.5 degrees.
Ive set it at that at idle with vacc disconnected, and it seems to run really nicely. It was previously at 15 degrees at idle and lacked pick up.
I only have about 20 degrees all in at 3000 rpm.
Owner says it sounds alot better and more throaty now, just from backing timing off a bit.
I just wondered if I need more timing, or does the usual advice about 30ish degrees all in mainly apply to the LA small blocks, and polys don't like so much timing.
It's a stock set up, 4 barrel holley with push button auto, and its really lovely to drive.
