Replacing ignition barrel/switch
Anyone done this job?
Could do with some hints as I read somewhere that I need to remove the steering lock ring which requires special tools
Any guidance appreciated.
- Location: oxford - the dreaming spires where cars in the city are banned
I've replaced the ignition barrel on mine, and it was a bit of a mission.
The barrel is held in by a metal pin/peg that has to be pressed in to release it, but you have to strip the steering column down quite a bit to get to the pin.
I managed to do mine with no special tools apart from a puller to get the bit underneath the steering wheel off.
Looks a lot easier than I thought it would be. Have a mate with a 74 Mercury Montego that needs to change his ignition switch as well, would have thought that the process would be the same or similar. Thanks for posting the link Miles
'68 Dodge Charger
‘75 Ford Ranchero
'93 Toyota Hilux Surf
YouTube - Double Zero Garage
‘75 Ford Ranchero
