…driving a fast hot rod is fun, unless it kills you.
GJUK
Post by GJUK »
Quote of the week for me.
Article here:
http://www.hotrod.com/articles/1968-ply ... harnesses/
good read on A Body safety tips. Is there anywhere in the UK that sells these driveshaft hoops?! :S
Good article that I think most of us don't really want to consider.
I have that Summit prop loop. Not difficult to install and worth the cost.
I also now have modern seat belts installed too. Bigger brakes.
When I bought tyres I checked out the stickiest ones available in my price bracket with no interest in whether they looked period: they don't.
Il probably spend more on better tyres again next time.
With a two door pillarless and fold down buckets, I guess I'll have to take my chances with the lap belts.....
GJUK
Post by GJUK »
Everyone needs a roll cage. :D
Hmm, unless you wear a helmet, you'd probably brain yourself on it if things went badly wrong..... just saying :?
shovelheadrob
Post by shovelheadrob »
Only had a propshaft break once, Bedford CF van, it pole vaulted it about 4ft off the ground at 60mph (flat out downhill with a tail wind!) happened so quick there wasn't time to be scared.
Had one break on the motorway, luckily rapidly broke both UJ's and threw the prop clear after it had wrecked the gearbox and smashed up the floor. Seen a few front UJ's break at he Pod startline, no big deal if the car is stationary, whole other thing if it happens mid track. If a rear one breaks, the prop is liable to come through the floor even if the car is stationary.
GJUK
Post by GJUK »
Blue wrote:Had one break on the motorway, luckily rapidly broke both UJ's and threw the prop clear after it had wrecked the gearbox and smashed up the floor. Seen a few front UJ's break at he Pod startline, no big deal if the car is stationary, whole other thing if it happens mid track. If a rear one breaks, the prop is liable to come through the floor even if the car is stationary.
....I'll sleep well tonight. Thanks :D
Does anyone in the UK make these prop shaft life savers?
mad machs
Post by mad machs »
Mythbusters had a crack at the jolly old pole vault, but met with limited success ...
http://www.discovery.com/tv-shows/mythb ... ole-vault/
Mike that is called Mike.
69 Dodge A108
73 Mach1 Mustang
Garp
Post by Garp »
Job number 1 tomorrow - getting under that girl with a spanner !!!!
Why'd you have to go and "put the Willies up me" !
A cocking large piece of steel coming through the floor ??????
Jeeeez lads !
GJUK
Post by GJUK »
Do you have a 727 gearbox, they explode in 1st doing burnouts :D
A cast iron hand grenade I think someone mentioned to me.
\o/
Not any more: bolt in sprag🙈
GJUK
Post by GJUK »
MilesnMiles wrote:Not any more: bolt in sprag🙈
What do you mean please Miles ? :)
The part of the 727 that is the weak spot is the so called sprag. Blue or Dunc will correct me but basically if you burn out in first gear the sprag is spinning at twice engine rpm, breaks loose of the clips that retain it and comes free through the trans case and floor and maybe yer leg too😱
I damaged mine with a bad burn out/stage and it sounded like demon was chewing it's way around the trans.
Limped home and pulled the trans for a heavy duty rebuild inc bolt in sprag kit
A good reason to ho manual eh Miles! They only explode flywheels and bellhousings :lol:
