Intake gasket
- shaungriff
Intake gasket
I'm planning to replace the intake manifold gasket on my 1973 360 this weekend. I've purchased a fel pro gaskets & it comes with 4 little plastic retainers. Am I right in thinking I push the retainers thru the new gasket then into the head so the washer type head is towards the inlet ? I'm just a bit worried it will stop the gasket sealing. Any advice appreciated. Thanks shaun
1973 Chrysler CJ 360ci
- shaungriff
I normally evo stick the gaskets to the head and leave them to set. remove the dowels in the end rails if there are any, use a thick bead of silicone back and front instead of the end seals and otherwise install the intake dry. That's the way the racers do it for a permanent leak free solution.
- Demon James
I have used the plastic retainers twice now on a 340 SB with no other sealant. First time was when fitting a new inlet manifold.
Second time was five years later on a refresh of the same engine, which still seals fine 3000 miles later
Definitely with Blue on the end sealant too. Dowels removed and a thick bead of gloop at each end instead of the cork gaskets
- shaungriff
So donthe retainers push into the gasket from the manifold side then hold the gasket to the head via the bolt holes ? So no sealant on gasket & no cork just rtv Thanks shaunDemon James wrote:I have used the plastic retainers twice now on a 340 SB with no other sealant. First time was when fitting a new inlet manifold.
- Demon James
Yep, that's how I did it anyway.
Sat the gaskets in position then pushed the retainers through the gasket into the cylinder head (second hole in from each end I seem to remember)
Then with the dowels remove from the block, because if they are left in they sit too high and may crack the ally inlet manifold. Followed by a good dose of RTV where the cork gasket would normally sit.
The gaskets I used had a soft, slightly raised compound around the water circuit holes so I didn't add anything else. I don't think it would hurt either way if a very small amount of rtv was added around these holes if you like.
- shaungriff
- shaungriff
