camshaft upgrade - recommendations?
Hi all
Removing the engine soon and was considering changing the camshaft to something a bit more hi-performance while its out?
Any suggestions/ideas/recommendations welcome?
318 V8 1972 Dart, already have a Weiand stealth Intake and Holley Street Avenger Carb if that helps with choice of setup?
thanks
Ross
thanks
Ross
- ScottyDave
- mopar_mark
Is a hydraulic roller not an option ?Pete wrote:I had a lot of challenges lately breaking in cams - do not under-estimate the issues nowadays; hydraulic and Flat tappet cams.
Some suppliers will insist on you buying their break in oil or they will not warranty the cam or lifters.
Yes it's just muddying the waters, you need a regular hydraulic cam nothing fancy. But since you asked and it's a slow day at work... instead of the normal flat bottom you have on a solid or hydraulic lifter, you have a rolling wheel. The advantages of this are, less friction, the ability to use a much more aggressive cam lobe and the fact that you can swap them around between cams. They also require no break in period like regular cams do, and that break in period can and often is disasterous if things go wrong. Modern V8 engines usually have hydraulic roller cams, serious race cars use solid roller cams. The downside is cost (double if not triple the price),more moving parts to fail and to service, Machining often needed to fit one.
Here endeth the lesson, move along please nothing to see here...
