MOTed car on Saturday expecting no advisories given the work that went into the suspension and axle over the last 2 years.
It passed YaY!
but i was surprised to get advisories on SLIGHT rear wheel/axle bearing play
these are new bearings on new axles in a housing that is in good condition
the bearing cups needed to be pulled out rather than falling out and new ones put in.
can't see any way to adjust so will just have to live with it i guess
axle has approx 1500 miles on it
can anything be done? or do i need near bearings and seal already
proper....branded bearings went in
small amount of play in rear axle bearings
Spicer axle
press fit collar to hold on taper bearings
middle bit of axle just floats in the side gear of the carrier
crazy 3 part seal that runs on the concave radius of the back of the hub flange
seal retainer held in with 4 studs
and a back plate for the brake
nothing to adjust
built by a specialist i.e I didn't do it. if i had i would expect something not quite right
nothing to adjust
- mopar_mark
