318 upgrades
318 upgrades
Can anybody recommend any upgrades to a 318 engine and what is the maximum overbore possible. Is it possible to turn a 318 into 340?
Andy
Andy
DaveBishop
As Blue says.....Budget?
A healthy 318 can get inot the 300hp range with a good match of parts and minor work. Carb, cam and compression etc etc.
If you want to make it really come alive you'll need to go down the stroker route. 390 or 392 is most common.
As I'm doing currently, the key is research, research and more research. Stroker kits are currently at around $2k......add shipping, Vat and tax.
That's the easy bit......The 318 will need to go to a proper engine place for boring, honing, decking etc......and the 000s just keep adding that's if you don't have any block issues. You'll need decent heads to make all that worth the expense. Eddys are around 1500 or you can port J heads, that'll still not be cheap though to get it done for best bang for buck.
At this point you have to weigh up the cost differential between going this route and buying a 360 and bolt ons........its a minefield and I'm still trying to navigate it.
Set yourself a target....BHP or 1/4 mile time. There is your starter for 10.
Ok a budget build, assuming the engine is in good shape to start with, electronic ignition with recurved distributor and a less pedestrian rear gear are your best bang for the buck. Next, viscous fan package, quality headers and a true 2.5" system, aluminium intake and 600 double pumper Holley. That's the fairly cheap and easy done. Cam, lifters, billet timing set and convertor to match is next, and that lot should get you in the 13's and totally streetable. That's as far as I would go with a 318, your spend to gain ratio drops considerably after that.
- octanejunkie
