dual carb linkage advice needed
charger01
Post by charger01 »
Has anyone got any recomendations on linkage set ups for a weiand highrise intake with two 650 Holleys?
Assuming the carbs are mounted sideways you can't beat the Enderle linkage.
charger01
Post by charger01 »
Cheers Blue. Is there any specific reason for mounting sideways? My set up sit normally facing forward.
A few of the reasons to mount sideways, you can get the float bowls off with out removing the carbs, so you can use double pumpers, not enough space to mount those inline, also allows space for a secondary metering block on a Vac sec.
charger01
Post by charger01 »
Cheers Blue , thanks for the input.
