GJUK
Posts: 2486 Joined: Mon Oct 28, 13 5:03 pm
Post
by GJUK » Sat Dec 30, 17 7:37 pm
Hi guys,
Does anyone know of any modern cheap wheel that would fit a 4.5"PCD large hub type mopar?
Just to move the car around with - so the old dart can have her wheels back
Thank you.
Jon
Posts: 17242 Joined: Sun Apr 18, 04 11:26 pm
Post
by Cannonball » Sat Dec 30, 17 8:45 pm
I have plenty of wheels for mopars good for moving arounds £100 for four
GJUK
Post
by GJUK » Sat Dec 30, 17 11:37 pm
You're miles from me - it wouldn't make sense to drive to/collect form you for this.
Any other suggestions?
Super Sloth
Posts: 692 Joined: Wed Oct 07, 15 6:46 pm
Post
by Super Sloth » Sun Dec 31, 17 12:30 am
GJUK wrote: Sat Dec 30, 17 11:37 pm
Happy to act as a half way point if someone is passing through? I'm @ J28 M1
-Jon.
Posts: 9570 Joined: Thu Feb 24, 05 10:31 am
Post
by Dave999 » Thu Jan 04, 18 1:10 pm
http://www.wheelsupport.com/bolt-patter ... 5-x-114-3/
2 13/16 inch centre bore necessary 71.4mm
most will have no dish
offset will often be too much with the inner of the rim hitting the spring
all L from the list would be ok 0 mm offset some M will be ok 20mm + offset
H probably won't but they may fit backwards for wheeling about
http://www.wheelsupport.com/offset/
Looks like Jeep might be the go....
dave
GJUK
Post
by GJUK » Thu Jan 04, 18 11:57 pm
Thanks Sloth
Thanks Dave - that is a comprehensive list.
Cheers.
Posts: 1913 Joined: Sun Jan 23, 11 11:32 pm
Post
by Captain Chaos » Tue Jan 16, 18 7:18 pm
Super Sloth wrote: Sun Dec 31, 17 12:30 am
Maybe you’re sorted GJ?
I bought a 2001 Jeep Grand Cherokee today that came with a second set of alloys with tyres,any use to you?
GJUK
Post
by GJUK » Fri Jan 19, 18 9:02 am
Hi,
I've not found anything yet - drop me a PM.
Thanks
