oil pressure on a 440?
whats classed as good oil pressure on a 440,mine is 65lbs-70 when i start up & about 45-50 ish ticking over warm,Ive been told this is too high & it should only be 45-50 lbs on start up,(engine runs well,not had any problems) any views on this?
I was interested in correct pressure after installing my rebuilt 360. One of the US Mopar mag articles said they were happy with 30psi at idle and 60 at cruise speeds, they indicated that 90+ was a touch high.
Mine sits at 30psi@750rpm, jumps quickly to 40-50 at 1,000-1200rpm and sits at 60 at cruise speeds. All figures are for hot motor and (new) standard oil pump.
Another question then chaps...
On start up my engines oil pressure sits around the 60 mark.
After driving for approx. 25 - 40 mins the pressure drops down to about 35.
Now all this tallies with what has already been said...... but.....
After another 20 - 30 mins there is almost a complete loss of pressure ( literally drops below 10) but will pick up if revved slightly, but then drops again.
have changed oil and filter. oil level is ok. any ideas
Thanks in advance
Thanks in advance
