My 3rd gen Charger at some point was jacked up at rear probably to clear the wheels, this was done with coil overs and multi position extended shackles, I now want to return it closer to stock. If someone knows, or could take the time to measure a stock one I'd appreciate it.
I need o/a length, width of side plates, thickness of side plates and the bolt centre's. I could then make up a replacement pair.
Thanks Dave
B Body Shackles info needed
- ScottyDave
Re: B Body Shackles info needed
- ado-45g13007_nd_xl.jpg (39.27 KiB) Viewed 737 times
- ScottyDave
