some documents and bits and bobs i had
attached
dave
engine DistressGuide.pdf
broken motor, read the symptoms, find the cause
(2.7 MiB) Downloaded 37 times
US six pack tuning.pdf
US six pack tuning
(542.78 KiB) Downloaded 35 times
Aust oil filter Cross_Ref.pdf
Mopars use a filter called a Z9 use it to cross ref with oems
(1.12 MiB) Downloaded 39 times
compare
compare
why is my carter carb equipped car running bad
Carter carbcard.jpg (97.55 KiB) Viewed 288 times
Oil filter comparison chart.pdf
compare oil filters aussie Mopars use Z9
(45.32 KiB) Downloaded 37 times
HEI ignition for your mopar
aaa hei_pic.gif (19.87 KiB) Viewed 288 times
if you wire HEI backwards
a backward trigger.JPG (38.03 KiB) Viewed 288 times
MSD-pill_rework.pdf
how to make your own rev limiting pills for MSD
(45.19 KiB) Downloaded 35 times
hei facts High Energy Ignition.doc
stuff about HEI
(46 KiB) Downloaded 37 times
