Which starter motor for my 572 coronet
andyrob
Post by andyrob »
Bust my starter motor at the nats for my 572 coronet, there lots of high torque mini starters available, and all over the place on price, the mini starter I used didnt turn the engine over very nice
I had to get the engine turning before flicking the ignition on,
whos used what for a big cube motor ???
This msd ones get great reviews but is alot of ££££
https://www.summitracing.com/int/parts/ ... make/dodge
life is not a spectator sport
www.andyrobinson.eu
andy robinson
68 572 coronet RT
72 440 chrysler new yorker
69 518 daytona
Re: Which starter motor for my 572 coronet
I think that is what I had in the 572 and it ripped 4 teeth off the ring gear on the Convertor. Plenty of Torque.
I would always use a Starter saver device on such an engine, it is not a Mondeo.
andyrob
Post by andyrob »
cheers Pete that sounds like just the job, it allready has a retarder on msd unit whilst starter is in use
Lets see what everybody else is using ?
www.andyrobinson.eu
andy robinson
68 572 coronet RT
69 518 daytona
Robb Mc make the most powerful one which lots of guys in the States rave about, it is the lightest too which is why I have one on the Valiant...
andyrob
Post by andyrob »
cheers Blue, found this on there web site:
Mopar Gen II Mini-Starter – PN 3005
Will NOT clear Megablock, Indy Max, or World Products blocks when using a 130t ring gear
any educated guess's how many teeth my ring gear will be ??
www.andyrobinson.eu
andy robinson
68 572 coronet RT
69 518 daytona
130 teeth is normal for Mopar Andy, I would have assumed it would be that. I have no experience with mega blocks so I don’t know if it’s normal for them to have a larger ring gear count due to clearance issues? Duncan, Dave B or Hauser’s will know for sure.
I have a mega block, and it has been ground away in the starter motor area....
My KB ran a 130T Ring gear/Flex plate. I have been using the Mezziere starter, like Pete, I had to slightly clearance the block.
FYI When I upgraded the starter, I ran a separate earth directly from the battery to the starter, made a big improvement. Motor span noticebly faster.
I have ignition retard via the ECU for cranking
andyrob
Post by andyrob »
cheers all, managed to get my old old repaired, but might still buy a new one to spin it over faster
www.andyrobinson.eu
andy robinson
68 572 coronet RT
69 518 daytona
