‘73 Charger part needed.
RAGNAR
Post by RAGNAR »
Can anyone help me? I need to find a driver’s side of whatever this plate is on my Charger, it fits just in front of the rear side window. I’ve tried searching ebay, The Paddock and Classic Industries but have had no luck so far. Really hoping to find this, to fill the gaping hole that greets me every time I open the driver’s door! :cry:
Re: ‘73 Charger part needed.
https://www.classicindustries.com/produ ... b1741.html That's the door one's can't see the body side.
I might have that can you measure opposite side ??/
RAGNAR
Post by RAGNAR »
Ok, no problem. Should be able to get up to the barn next weekend. Unfortunately I have limited access to it, due to the times that the owner is there and my work hours :(
RAGNAR
Post by RAGNAR »
Cannonball wrote: Sat Aug 18, 18 11:24 am I might have that can you measure opposite side ??/
Finally got there! It’s a rubber fitting. About 135mm long, and around 80mm at the widest part at the bottom.
