Lifters
Duster1
Lifters
Post by Duster1 »
Hi Guys,
Advice please. I’m just about to reinstall my original hydraulic lifters and wondered if there’s anything I need to do prior to install.
Do I just put them back ,do I need to remove the oil from them or do I strip down and clean each one.
Just want to be sure I get it right.
All the lifters and cam are in good condition with no signs of wear and tear.
Thanks
Andy
Re: Lifters
Are they still in EXACTLY the same order in which they came out?
If not, then bin.....
Duster1
Re: Lifters
Post by Duster1 »
Yes Pete
All in same order as came out.
Re: Lifters
Phew!
Some people soak lifters in oil before assembling the engine.
I would install them, and then Pre-oil the engine and then set the pre-load on the lifters prior to start up.
Duster1
Re: Lifters
Post by Duster1 »
Hi Pete,
I have a 318 engine, which has no valve adjustment at all, so does the preload still apply.
Cheers
Andy
Re: Lifters
Nope, just whack them in and let the engine sort itself out....sorry - I am used to adjustable Rocker gear...
Duster1
Re: Lifters
Post by Duster1 »
Pete,
Thanks for your help mate.
Andy
Re: Lifters
You are most welcome!
Good luck with the progress - we need pictures!
