Valve stem seals
Valve stem seals
Hi need a bit of guidance, I'm in the process of rebuilding my 273LA.
After lapping the valves, I was reassembling the stem seals and this is where I'm a bit confused. The inlet seals fitted in a manner I'm used to but the exhaust seal just seems to sit there above the guide with no positive way to secure it and slides up and down a little with the valve...is this okay? I've tried searching the Web but drawing a blank.
TIA
Cheers Dave
Re: Valve stem seals
umbrella seal
unless its really too big for the valve stem looks like my orginals
Cheers Dave, thought that was the case :thumbright:
Unfortunately I'm a seal short either the kit had 1 missing, unlikely or I've dropped 1 somewhere, most likely. Had a good look around the garage but no joy so have had to order another kit.
are they standard mopar valves
i may well have some every full gasket kit comes with some but i have thin stem valves and press on seals
i'll have a dig
pm address
kma176
Post by kma176 »
I have spares if you need them ??
Dave999 wrote: Tue Jun 04, 19 9:36 am are they standard mopar valves may well have some every full gasket kit comes with some but i have thin stem valves and press on seals
i'll have a dig
pm address
kma176 wrote: Tue Jun 04, 19 10:25 am I have spares if you need them ??
Cheers lads, never occurred to me to ask through the club and I ordered a set from US Automotive which arrived today.
Cheers :salute:
