The Daily.... that I took apart.
When I worked at Ford my manager would always make comments on my lack of brand loyalty because I’d drive a big smelly diesel Ram to work. He suggested I buy a ford product. So I asked for a Mondeo wagon, but apparently we aren’t allowed them in the US. So I asked for a stick shift truck, it too turns out we can’t have them in the US.
There was an impasse.
Then I found this:
Then I found this:
- 8E49B181-3310-46FA-B0F9-A22CF556AC83.jpeg (136.46 KiB) Viewed 2612 times
Re: The Daily.... that I took apart.
For some unknown reason my manager wasn’t pleased with my choice
Then, naturally, I took the engine out of it and didn’t work on it for 2 years..... grrr.
- F930C641-D624-46E1-833A-F0CB4863BBD8.jpeg (167.65 KiB) Viewed 2611 times
Old one. Picture doesn’t really do it justice. It leaked so bad I was adding a quart a week almost. And it fouled no8 plug about every 300 miles.
- BAAC5590-53A3-49BE-A6EE-563E8E01514D.jpeg (184.11 KiB) Viewed 2611 times
New one. Mmmm shiny. Mustang GT specs, only I didn’t want to mess with firing order for the HO. So I have a custom grind cam for the 1-5 firing order. Should be roughly 300hp, give or take.
Oddly enough I’m keeping it 50 state legal.
- 9D57BDD3-CD1B-4CA8-92AE-175DC97707A0.jpeg (182.96 KiB) Viewed 2611 times
- Trigger_Andy
Cool project James!
Interesting you're able to change the firing order.
It’s not that I changed it. Ford did it themselves. There were 2 firing orders on the Windsor engine. In this period the HO engines ran on 1-3 and the truck and full sized car engines ran on 1-5.
In this case I was bolting HO bits into a full sized car. But I wanted no part in re wiring a 30 year old loom to put the injectors in the right place etc. so whilst I was buying a cam I just asked them to grind it on the non-HO order. Didn’t actually cost much more money.
That workshop is something else, if it makes that car look small inside there!
- Trigger_Andy
What was the reasoning behind the two different firing orders?Bratfink wrote: Tue Jul 28, 20 5:58 pmIt’s not that I changed it. Ford did it themselves. There were 2 firing orders on the Windsor engine. In this period the HO engines ran on 1-3 and the truck and full sized car engines ran on 1-5.
1 & 5 are on the same journal. I asked some old timers when I was at Ford about that. Apparently it was an attempt to spread the input forces between the journals on consecutive firings.Trigger_Andy wrote: Wed Jul 29, 20 3:04 pm What was the reasoning behind the two different firing orders?
I guess we’re about to find out if it was needed or not
I didn’t want to say anything, but that isn’t the workshop. That’s my regular garageMattH wrote: Wed Jul 29, 20 10:34 am That workshop is something else, if it makes that car look small inside there!
