Best size tires for 15" x 10" steelies
Hearserider67
Post by Hearserider67 »
Hi, I'm wanting to know the best size tires to go on 1 5" x 1 0" steel wheels ? Regardless of inset etc,
Ideally BFGs,so unsure of their size patterns , these are for my Barracuda rear wheels, don't worry about clearances or arch rubbing :D , cheers Ian
Who taught you to drive.....Evel Knievel !!!
Re: Best size tires for 15" x 10" steelies
It depends on the intended purpose.
If taking it down the strip then look at Drag Radial options.
If it is street only then the old favourite 275 x 60 x 15's are a option... relatively tall tyre...
Hearserider67
Thanks Pete, yes only street, I don't have plans for the strip... :)
Where is the best place to get these from ? Ian
I have always used North Hants for my tyres.
Hearserider67
Okay will try them for prices, cheers Captain! :o :)
kma176
Post by kma176 »
I've used 295/50/15 BF Goodrich TA radials on mine but only on an 8"x15" rim not sure with a 10" ?
Use Northants tyres site to get tyre dimensions. For best fit and look match the tyre tread width to the wheel rim width. Then choose the profile to give you the overall diameter you want.
I have 275/60/15 on 10” rims on my Vandura and they look right.I went for these as they were taller than a 295/50,about an inch and a half,wanting a bit of ride height and rubber rake too.
Hearserider67
That's the look I'm after mate ,cheers :thumbright:
HarrySaggs
Post by HarrySaggs »
28E41157-303A-44F8-930B-7E6A1C1D479D.jpegE6D892F3-D4EB-4CCA-A20C-8E50BC339B6C.jpegI have 275/60/15 on 10” rims on my Vandura and they look right.I went for these as they were taller than a 295/50,about an inch and a half,wanting a bit of ride height and rubber rake too.
Wow! Are those BFG Radial T/A tires? We have the same set of tires, though I got mine from one of those wheel and tire packages which you can purchase online. What specific brand of rims do you use?
HarrySaggs wrote: Mon Oct 05, 20 12:48 pm
They are US Indy Mags I got through Summit. I bought the tyres from North Hants.
HarrySaggs
US Indy Mags? How much do they usually cost nowadays?
From memory about £800 landed for five when I bought them three years ago.
Have a look here.
https://www.summitracing.com/search/brand/u-s-mags
