Change of pipes
- Gas for GOSH
Change of pipes
Haven't posted anything for ages so here are some pics of the cat back exhaust change on the Charger a while back. I did some research on the difference between Magnaflow and Flowmaster, there was only one Magnaflow option for my car but loads of Flowmaster ones. It's not easy to tell from listening to a video on the internet but I had Magnaflow on the Mustang I used to own and it had a real nice burble around 2-3000 revs. Others may disagree but to me it seemed if you wanted better noise go Flowmaster, if you wanted a little more performance go Magnaflow. For my car the Magnaflow pipe is more straight through as I checked by shining a torch right up it. The other factor was drone...I drive the car every week on short and long trips and I did not fancy constant drone which the Flowmaster super series can produce. So I went Magnaflow - it has a more throaty sound under the hammer for sure. If anyone wants the old factory exhaust for a 2006 5.7 Charger it will be in the parts section.
- DSC_1058.JPG (120.27 KiB) Viewed 595 times
- DSC_1069.JPG (129.45 KiB) Viewed 595 times
- DSC_1076.JPG (86.3 KiB) Viewed 595 times
- DSC_1091.JPG (139.67 KiB) Viewed 595 times
- DSC_1096.JPG (179.83 KiB) Viewed 595 times
- DSC_1106.JPG (85.38 KiB) Viewed 595 times
- DSC_1108.JPG (124.15 KiB) Viewed 595 times
Re: Change of pipes
Looks nice, have you actually tried it out yet on a longer run?
Drone is very wearing after a few miles, something I need to eliminate on Mandie's truck, but it only has cherry bombs with side exits at the moment!
- Gas for GOSH
Re: Change of pipes
Yes Matt had a long run past Bath and back the cabin noise is slightly up when cruising but still easy to talk ....my Mandy says I have selective hearing anyway! There was one decent review on you tube that had a decibel reading for all the different Magnaflow and Flowmaster options on the same car. One of the reasons I chose as I did. I also have an Airaid cold air intake to go on it....allegedly in combination the change of exhaust and air intake gives 40 hp and 5-10 more mpg on this engine.
- mopar_mark
Re: Change of pipes
I bet there are not many times can you say, adding more power provided a cost saving... Sounds like a great investmentGas for GOSH wrote: Thu Oct 29, 20 11:53 pm..allegedly in combination the change of exhaust and air intake gives 40 hp and 5-10 more mpg on this engine.
