So I have been meticulous with my measurements, however, when I installed my leaf springs and rear shocks (just some cheap Gabriel’s from rockauto to get the car on wheels) the right side frame rail seems to push up 7mm higher than the left at the rear.
The leaf spring hangers are an exact equal distance and measure the same on both sides.
I’m not sure if this much flex is normal and I’m just worrying about nothing, or if there is an cause I should be looking out for.
The leaf springs are the same ones that came in the car, they were blasted and restored but NOT tempered.
When I release the tension off the frame, its falls back to level….
It’s got me scratching my head, however I’m sure one of you Mopar geniuses can shed some light on the matter
