OK so following on from my introduction I'm guessing that actual knowledge on the car (2013 charger srt8 )at garages may be a bit thin on the ground
Are there any specialists near the Midlands that can do indepth work if needed ?
Ideally I want a full service including trans fluids belts the lot just to be certain it's all up to scratch.
I'm not fussed if I have to drive but it needs to be worthwhile
I'm slso struggling to find out how I can get european maps added as it's very basic and not accurate atm
Trusted garages
Re: Trusted garages
Hi Dharmalama,
Not sure where in the Midlands you are, but Jim who's a member on here, runs a garage in the Midlands. His username is 'Challenger'.
He has helped several members with their cars.
see this older post:
viewtopic.php?f=1&t=53462
hopefully it's still valid.
PS his Challenger ain't bad..
- jims mopar parts and challenger 007 (Large).jpg (111.42 KiB) Viewed 578 times
Re: Trusted garages
That's fantastic I'm actually near worcs malvern area so even better
Thank you very much
Thank you very much
Re: Trusted garages
I will second that, Jim is very good and very reasonably priced too.
Re: Trusted garages
Yes Jim is very good with his Mopars
