Thought I'd give a quick update on my 3rd attempt to tame Andy's Charger's backfire. Found lots of things it isn't, but still can't diagnose it
Firstly, I took the dizzy cap off to check the reluctor gap, and found... a set of points! Yep, the electronic ignition module on the firewall fooled me into thinking that it had an electronic dizzy, but someone has swapped a points dizzy in. The module's wires are taped into the wiring loom, but don't actually go anywhere. Anyway, the points looked new, but the gap was about 10 thou, so I re-set the dwell (and timing, of course). It ran better generally, but still spat back through the carb once it warmed up (is that a clue?).
We then swapped the 600 carb for my known Holley 750, which made no difference at all, so the carb is ruled out. Fuel pressure is fine too.
Vacuum test showed a steady 17" at idle, and behaved as it should when the throttle was opened and shut quickly. So, I'm pretty sure there aren't any vacuum leaks, but we test blocked all hoses anyway, including the brake servo.
I'm starting to think it has to be electrical. It has high quality new plug wires on it, but we made sure they are separated properly. Andy will try a new condensor, but after that he will take it to a place that has diagnostic equipment.
