A rusty E-body question
I sand blasted the firewall on the Challenger at the weekend, and as I expected it needs a bit of work. At either end is a factory hole around 8" across. I know the one on the passengers side is an air intake for the heater box, but I can't remember what the one on the drivers side is for. It needs repairing, and if its not important I'll just get shot of it.
What is this hole for?
- Cannonball
- Cannonball
Agreed , it is the fresh air intake , there is one each side, one goes through into the heater, the other straight into the car, you need to make sure the upstand around thee dge is complete and sound or all the rain water running through the heater plenum runs straight into the footwells and rots the floors. Ive done all this job on my Chally, much easier to bite the bullet and cut a big lump off the top so you can get right in there, then weld it back on afterwards. It is mostly covered by front fenders anyway.
Dan, I just rea;lised youve gone bolder than I and cut the WHOLE of the top of the bulkhead off, I just cut either end off. Well done for getting stuck right in. It will be worth it in the end.
- Cannonball
yours should still have that body pressing dave and the fresh air pot hanging down off it, and matt is right it has a tower sticking up around 2" high to stop water running in easy to make and then seam seal around it to be sure, then make sure you have noce water drain aways from each corner off that lower bulkhead
- Dave-R
NOPE!Cannonball wrote:yours should still have that body pressing dave and the fresh air pot hanging down off it,
I thought it was funny that it didn't ring any bells with me.
MY CAR DOES NOT HAVE THIS.
I reached in as far as i could but couldn't feel it. Then I stuck my little digital camera in there and took some photos. Nothing there except loose rust and old cobwebs.
Then I took a shot looking up under the dash to where the "fresh air pot" would be. Just plain steel.
Maybe this is something that was added to the cars later in production? My car was built October '69.
Thanks for all the help, nice to see i'm not the first to tackle this. Was a bit worried about cutting off the top of the bulkhead, but now its off I'm glad I did. Makes repairs a lot easier.
I think i'm going to plate this hole over then. If Dave doesn't need it, then neither do I, I haven't got a fresh air pot anyway.
