Suspension clunk????
Hi Guys,
I have noticed that there is a definite"clunk" on the drivers side when I fail to negotiate the many potholes, no matter how small, we now have in nearly every road in the country. On the rare pieces of smooth tarmac everything seems ok. Sometimes the clunk can be more pronounced when turning at the same time. Any ideas? My son and I have looked underneath and everything seems to be "in place".
Car is 69 Roadrunner. Car is due for MOT and I don't want examiner to see something that a blind man could spot at 50 yards!!!! Many thanks in advance for any help you can give.
- Dave-R
I agree with Alex and you should check that first. However if it is that or not that check the other suspension joints as well because if one is that badly worn chances are the rest need replacement too.
The list to check is;
UCA and LCA ball joints.
LCA and UCA pivot bushings.
LCA strut bushings.
Tie rod ball joints.
Pitman arm ball joint.
Idler arm ball joint and pivot.
May as well check the wheel bearing adjustment while you are on.
LCA strut bushings.
