It’s a 2-spoke rim blow type, got the cover off, un-done centre nut. Now, there’s 2 threaded holes in the steering wheel hub either side of the steering column shaft. Can I drive a couple of bolts into these holes till they bottom out and lift the wheel off?? or do I need a puller?? Or something else??
Thanks in advance
Help Removing Steering Wheel
Thanks guys. I had a go last night but the puller I was using obviously isn’t the correct one and I couldn’t get a decent hold on it. It does appear to be on quite tight?? Thought of your method too Dave but didn’t have any suitable materials to hand
Alex; any chance of a borrow please?? I’ll give you a call later
Cheers
Cheers
