wing mirror is broke
I was cleanin the car yesterday, went to move the wing mirror and it came loose on the pivot joint, its a 70 barracuda standard type (non remote mirror) the mirror section is still attached to the base, but the half of the pivot joint is rattiling around behind the glass, Anybody know if these are repairable?
Cheers
SteveCase
Post by SteveCase »
Had mine to bits a few times, sure you can fix 'em.....it'll certainly be easier AND cheaper than trying to buy a new one!!!!!!! :?
I will not be drawn into a battle of wits with an unarmed man!
Kewl, removing the glass is the trick I guess,
Cheers
