What gears?
- Rogue Trooper
What gears?
i`ve turned the rear wheel after marking it, like some of you guys said, it turns one revolution, to three turns of the propshaft, can any tell what gears i have?
1934 Coupe
1954 F100
1972 Norton Commando Fastback
Your Mum Says Hi.
Mopar a God amongst insects.
1934 Coupe
1954 F100
Your Mum Says Hi.
what gears
by memory i all ways thought it''s 10 revolutions of the prop and then count how many times the wheel rotates, or it might be the other way round , i forget now .i will check tomorrow , might be completly wrong though.
Re: What gears?
3.55 ratio is 1 turn of wheel,to 3 1/2 turns of prop.you must have 2.99 ratio.Rogue Trooper wrote:i`ve turned the rear wheel after marking it, like some of you guys said, it turns one revolution, to three turns of the propshaft, can any tell what gears i have?
- Rogue Trooper
what gears
forget my last post i was talking rubbish my memory is not what it was
it IS one turn of the wheel to how ever many times the prop shaft turns. sounds like 2: 94:1 , same as mine. 1 turn of the wheel to 2 & 9 tenths of the prop.
- Rogue Trooper
i had the car jack up, both wheels turned the same way, one turned of the wheel, three turns of the prop, when i went out with the owner of the garage, on a test drive, he said it shifted through the gears quite quickly? does this fit in with the gears that we`re talking about?
1934 Coupe
1954 F100
Your Mum Says Hi.
1934 Coupe
1954 F100
Your Mum Says Hi.
- Rogue Trooper
so sweetheart what should a warm 440 have in its axle
1934 Coupe
1954 F100
Your Mum Says Hi.
1934 Coupe
1954 F100
Your Mum Says Hi.
