Air con gas? i'm to hot.
OK guys I need help to cool off.
I'm running two cars both with the great big lumps of air con motor jammed on top of the engine and i cant get them re-gassed anywhere.
I understand that I need R12 and it is dodgy stuff.
Can any body help 73,78.
Bob
when i got my 78 fury topped up, they didnt have / weren;t allowed to stock new R12 gas, but they had some they sucked out of someone elses car, so they squirted in a bit of that,,, sorted.
i've always wondered if it was possible to pump the gas from a working car into a non working car just by connecting a tube between the two somehow!
charger01
Post by charger01 »
Halfords sell the gas & the kit to re-fill
Halfords
Adrian,
Alford's are you sure?
have anyone done this successfully?
Air con
Adrian,
Alfords are you sure?
Has anyone done this successfully?
air con
Sorry I stuttered.
are yo uSURE its the old gas they sell not the new stuff? (r143a)
You'd have to vac down your system then introduce the other cars stuff into the vac via a valve.......
air con
I cant believe it!
This must be a common problem I will have to look into this sounds like there could be a bit of business here for someone with a bit of nous.
Come on the twins your our fountain of knowledge.
Im still ot :(
charger01
Post by charger01 »
Sorry dont know which gas ,but they do sell kits to re-charge your A/C
Rebel
Post by Rebel »
Mines the same, it was great through the winter but now its just too hot, I was told on Sunday that it could be because I don't appear to have an air-con radiator, is this correct?
The Satellite I was looking at has an air-con rad sitting in front of the engine rad. I've never seen this on a charger, are Satellites different?
'68 Dodge Charger
‘75 Ford Ranchero
'93 Toyota Hilux Surf
YouTube - Double Zero Garage
Re: air con
Knightcharger wrote:I cant believe it!
Im still ot :(
mustard mit Bob, I know nowt about a/c but I was going to suggest you ask at Bob Harman's garage - they have all sorts of US & other old cars in there, I'm sure they've been asked to sort out old a/c systems ??
cool
Well done Rob I new you would come through I will ring Bob tomorrow and let you all know.
My RR certainly has a separate skinny air con rad in front of the water rad.
I will also do a bit of surfing and report back.
In the meantime.
I'm getting otter :oops:
hummm now i want to get mine done :?
SteveCase
Post by SteveCase »
Me too, IF anyone finds somewhere local, (south), maybe we can get a group booking/discount!!! :Ram:
I will not be drawn into a battle of wits with an unarmed man!
