Seat belts Front and rear 68 Chgr
vipergts
Post by vipergts »
I still have the lap section installed in the front of my Charger but the diaganol strap is missing. I note that there is a hole in the headlining above the rear qtr glass with a seat belt bolt hanging out.
Also the rear belts are missing (clearly the previous owner didn't like safety)
Where would I get new/replacement items from that are close enough to the original look. I have emailed Year One but had no response.
Help much appreciated as the war dept won't let the kids out in it till it's belted.
lee
68 Charger 440R/T
66 Sting Ray 427
67 Mustang 390GT Man
68 Corvette Stingray Rdstr
08 FGT
Try Ssnakeoil (type into google - they are an American firm). They restore / supply them to show quality standards. But, beware, they are hideously expensive and you may need a defibrilator on hand when you hear their prices.
I would have thought trying Duncan Watts (Cannonball on here) would be a good bet.??
Good luck Kimosabe :)
Got mine (correct date code too!) from a brakers in Alberta Canada.
But that was in 1989.......
Are you desperate for originality?
If not I'd go with a more modern and easily accesible belt, lie the securon belt. That way you get the inertia reel etc and it'll only cost 30 odd quid a belt. You will probably need to get a different fixing bolt for the roof mount though. But as long as it is high tensile and with the correct thread it should be fine...
i searched everywhere for a set off front belts, (found the back ones under the seat :D ) in the end i had to bid for several sets on ebay untill i won some, they seem to be like rocking horse poo to find originals :(
Got my belts from Canada via Ebay £60 inc the freight. Mine came out of an Imperial,they fitted fine. Can't find the sellers name ,but he often has belt sets for sale.
ive got sets of recolling seatbelts (new and used) Britax make, some are specifically designed for pillarless cars and have a drop strap thing from the roof bolt
On a similar vein (not wanting to hijack the thread) but my Charger has the lap belts (reel on the sill side, and fixed length on the centre side) and also has a strap running along the top of the window (which seems to have its own latch).
Is this the mysterious 'shoulder belt' of which you speak ?
Alex
Post by Alex »
yep !
Double buckle set-up,one for lap,one for shoulder.
The diagonal belt and second buckle was an extra cost option, yes?
vipergts
Post by vipergts »
Wow.....what a response
Thanks guys, lots of info there to go with.
Still trying to figure out if the diagonal belt comes from the roof mount or is that mount just a hook.
cheers
68 Charger 440R/T
66 Sting Ray 427
08 FGT
if it`s like the setup in my Barracuda, then the diagonal belt is bolt fixed above the rear quarter window and the belt is stored on two roof mounted clips parallel to the door glass (see pic). In use, it clips/hooks to the recoiling lap fixing mount. They are useless unless you pull them really tight, then you won`t be able to reach the switches unless you have monkey length arms :D
Check under the back seat for the rear belts, they may still be there.
