trying to find out what engine i have
charger01
Post by charger01 »
2568130= 383 ,1959-71 type B
charger01
Post by charger01 »
You looking over my shoulder then Kev?
I do believe you are looking over MY shoulder! :D
charger01
Post by charger01 »
:roll: ;)
What is the date cast into the block?
DaveBishop
Post by DaveBishop »
On some 383 and 440 blocks there is a machined pad near the distributor that has the size of the engine the year code letter and the letters HP the 5bhp difference may be the difference in the exhaust manifold used
2 x 1969 Dodge Darts
:iagree:
But I was going to check against the engine spec for that year just in case there were any other differences such as carb, cam or compression. ;)
You can lose 5hp having a bad air day! (Or £80 if you go to Trevor Sorbet like me Moosus! :? )
The lower horse 383 had a 2bbl carb, the 335 had a 4bbl. The difference is in the inlet manifold and carbumerettor :)
DaveBishop
that's right clivey but if it only 5bhp difference then its probably just the exhaust manifolds you got that sort of difference of only 5bhp when they put the 383 in the darts and had to revise the exhaust manifolds
