Best way to raise rear end?
What the best way to raise or stiffen the rear end? Some times it is necessary for me to raise the back end of the satellite due to lots of luggage or heavy passengers weighing it down and the Bananarama! the arches. I am currently running KYB air shocks.
What size are the tyres?.Air shocks are a bad idea full stop,as they load the spring perches/upper shock mounts.Best way to solve the problem is to rearch leaves or fit a set of heavy duty hemi springs.some get over it by using longer rear shackels,but all this does is bend the springs & cause wind up on hard acceleration.I know you didn't really want to hear that.
Fit mono leafs, available in different ride heights and stiffness
http://www.mopartalk.co.uk/mopartalk/vi ... php?t=9428
Not really no as I have extended rear shackels too.Adam68 wrote:What size are the tyres?.Air shocks are a bad idea full stop,as they load the spring perches/upper shock mounts.Best way to solve the problem is to rearch leaves or fit a set of heavy duty hemi springs.some get over it by using longer rear shackels,but all this does is bend the springs & cause wind up on hard acceleration.I know you didn't really want to hear that..
Just off down the pub meself,problem is,I can't remember if I told the wife if I was having 2 pints and be back at 10,or 10 pints and be back at 2.Pete wrote:Trolley Jack
Sorry, that's just the red wine talking, I'll get me coat.
