Will's 1969 Plymouth Fury Convertible. Restoration thread.
yes. Thats the front end made.. can't try it out until the back is done!
That looks good Will.
looks good will :thumbright:
Back is done, so have now removed back axle and springs.
Time for a jack up and test spin.
Car tries to touch floor at this point so it needs to go up an inch or two, but its nearly there. Progressing anyway.
That's one big ship to start twirling around Will!
Great to see some progress being made, it's a great car.
MrNorm
Post by MrNorm »
Nice Will, always wanted one of them :thumbright: :thumbright:
Did you weld up any bracing across the doors - them verts are awful floppy!! Don't do any major bodywork without making sure it's squared up!! Really looking forward to more pics
BTW - if you are still looking for K-member bolts, they are now finally being reproduced
So far it seems very rigid, but if the rear quarters end up coming off I will be putting in a big X brace .
Whos doing the bolts?
MrNorm
Post by MrNorm »
WillDatsun wrote:Whos doing the bolts?
http://www.rtspecialties.net/proddetail ... od=2467693
Or refurbed for a lot more.....
http://www.billrolikenterprises.com/pro ... 93%2DP%2DR
Thanks. doesnt give the size so I have emailed them.
one upside downey car.
once both frames are connected together with some more box section the whole thing should be transportable on the casters at any angle or height.
got meself connected..
Time for a degrease and pressurewash.
Nice work :thumbright:
Did you copy another rotisserie or make it up as you went along?
looked at a few for inspiration, some good, some quite bad designs.
Tried to get it up on the trailer today but I need to mod the wheels to get more ground clearance.
Jetwashed underside and exterior, and most of the paint flew off.
Swivelling casters upgraded to two wheelbarrow wheels. Other end raised by 2 inch spacers. Got it on trailer ok.
Lowered down for transport.
Delivered to bodyshop 60 miles away.
