Charger less at the Nats
Bugger.
At least you know now.
JohnR
Post by JohnR »
Taht is a real bummer Derek at least you can sort it after the nats , what is the crank like ???
John Rutledge
Don
Post by Don »
Sad news indeed Del, time for a hemi? :thumbright: :thumbright: :thumbright:
PETTYBIRD wrote:Sad news indeed Del, time for a hemi? :thumbright: :thumbright: :thumbright:
Don, If you want to buy me a hemi to put in the Charger I will gladly fit it.
charger01
Post by charger01 »
Bad news Del. Sorry to hear that. I know how you feel as I was without the car last year. Just doesn't feel the same does it.
Sell the Charger, Del.....................................and get a "C" body ;) ;) ;)
Don
Post by Don »
No probs Del, already got a hemi in stock, nice economical 2.5 litre out of a Daimler Dart :thumbright: :thumbright: :thumbright:
NaughtyAlan
Post by NaughtyAlan »
If that were the case dell, your oil pressure would be lower than normal :?
Wouldn't mind having a bet with yer, that it was what i said it was.Iv got a stethoscope if you need it.
Really need to have a listen, then strip it and see.
NaughtyAlan wrote:If that were the case dell, your oil pressure would be lower than normal :?
So whan are you and Adam coming south of the river to have a listen. :lol:
Mick
Post by Mick »
Sorry to hear this Derek, you certainly have had your fair share of bad luck.
Mick
Mick wrote:Sorry to hear this Derek, you certainly have had your fair share of bad luck.
Mick
Cheers Mick, and cheers to all those that have given me advice and the offer of parts, this will be my first nats without the Charger, but I will have my mate John Smith with me.
R.RUNNER wrote::P :P :P
yer a strange man mr runner
THATS a prototype hemi 6
is that the one in coventry? thought theirs was a production NOS 245
if you ran that in anger the harmonics from the cam would smash the distirbutor bushes to bits in 30K miles if you took it over 3000 rpm
although it will be a thick wall casting...you could take it out 90 thou to 4 inch and build a daft slow revving slugger
Dizzy is at the primary node for cam flex and twist harmonics and used a slant 6 bronze gear on the dizzy mounted bang in the middle of the longest unsupported run of camshaft
production version has it set back behind the coil near a bearing and uses a nylon gear
secondary node but 70% less vibration...... aussies didn't fall for the same trap as some of the others who's sixes were ultimately not suitable for passnger car use...living a life as industrial and truck engines...if you want it to rev out at 6000 you have to change yer casting...
anyway del
you can have a go in mine................................up the access road obvioulsy i've seen you drive andys car
its got a sixpack :)
