Maybe looking for a chassis tilter.
Anyone seen these before?
http://www.cjautos.org.uk/phdi/p1.nsf/s ... ent&part=5
Chassis tilter?? anyone seen this?
- sidewaysjas
bodytilter
I have seen the CJ Autos tilter and it is very good. Trouble is the model strong enough for a charger is about a grand !
I would also be interested in plans on how to make one, PLEASE !!!!!
Jason
Jason
Dont have any plans, it wasn't that good!
This is the best pic i have. bit of 2.5 inch tube ans some 2 inch too. Reinforced the top with some box section and two supports for the front of the tube. Though you cant see it it the photos, i did fit stabilisers when i did the charger cos i got the centre of gravity a bit wrong.
The car specific bit consists of a 2x4 box section with the 2 inch tube in the centre, then various brackets to bolt to the shell. I always use the bumper mounts + 1 other to stabilise it.
To lock it in position, i drilled a couple of holes through the tubes and just used a 10mm bolt to lock it.
Just make sure your welding is good and that the tube goes THROUGH the 2x4 box section.
Make sense?
Make sense?
