barrel
Did my 70 last year but am struggling to remember.I do know that its very easy,you just have to poke a small screwdriver/pointer down a hole some where which releases the barrel from the housing.
I know this aint no tech reply but knowing this may help you till I remember,or some one with more grey matter comes along
- latil
Take off the lock lever guide plate(the black triangular bit) underneath that you'll find a small hole. Put key in lock,turn to lock position and remove key. Insert a small rod or screwdriver in to the release hole and push to release lock. At the same time pull the lock barrel out.
